I have issue to find explore in grafana
i check the grafana.ini and the explore was enabled
but in my panel its not avalable
Did you restart the grafana service after the change?
yes but still have the same result in the picture above
I bet you have to login first and used user must have admin/editor role, … - see doc Explore | Grafana documentation :
In order to access Explore, you must have an editor or an administrator role, unless the viewers_can_edit option is enabled.
