grafana dashboard and folder have Privilege management,but Explore not.
How can read-only users view logs through Explore?
thx,bro
Hi!
The short answer is: they cannot. See my answer here:
yes.I see.Finally I adjusted the permissions from read-only to editor, and now it works fine.
thank you very much,bro
According to this GitHub issue this is possible by setting the viewers_can_edit option to true in the [users] section of grafana.ini.
