We are using Loki as a datasource for logs and Explore seems like the only option to query logs. If the user is in Viewer Role, how can we enable “Explore” for that user in Viewer Role ?
-Sumant
-Sumant
Hello @sumant, you can query logs in dashboard by using logs panel. Also you can use the viewers_can_edit setting. If you set this setting to true, then users with the Viewer role can also access Explore and/or make transient dashboard edits, meaning they can modify panels and queries but not save the changes (nor create new dashboards). This is also used for example in our grafana.play .
