Hi!
Im trying to split some Elasticsearch values (jenkins jobs dir paths) into variables, so I can filter by job the dashboard.
The structure of the field is: DSI/enviroment/folder_1/folder_2/job.
So, I have different combinations
For example (not real paths):
DSI/dev/monitoring/alerts/teams_webhook
DSI/pre/monitoring/alerts/teams_webhook
DSI/pro/monitoring/triggers/cpu_load_fix
DSI/dev/programming/....
So, I want to get the following variables
-Enviroment
-Folder_1
-Folder_2
-Job
To get these variables, I’m combining term queries to filter each path as I select variables (this works incorrectly) and regex (to get the exact word between the /).
(data.buildVariables.JOB_NAME =~ data.fullProjectName.keyword)
To get the Enviroment I use:
To get the other variables I use:
I just change the query (adding the previous value) and the {1} vallue, by {2} and {3} to get the other positions.
As I mentioned earlier, the issue is that sometimes, when I select the variables and reach Job, instead of filtering properly, it returns all the available Job Names. I think this is because of how Grafana escapes the / characters to query Elasticsearch.
No matter what I change, I can’t seem to resolve it.
Thanks in advance for any help or suggestions!
