Dynamic dashboard Query variable label
Hi!
I have a dashboard query variable that queries an elasticsearch datasource for a field value - it’s a hostname, to be specific.
I’m using this hostname as a parameter to Text panel that shows netdata dashboards, which I then set to repeat across all values of the variable. IKR?! So cool. :sunglasses:
The documents that the hostnames come from also store a friendly name for each host, so I can get a list of friendly names. I want to have the associated friendly name as the title of each relevant panel.
It’d be great if a variable could actually be a Tuple, where one part is the value and the other the label.
Is this even possible?
Yes, I think what you want is possible. Will depend on how you actually query the labels you want to use. See if Filter variables with regex | Grafana Labs maybe works for you?
Ok, cool! So at the moment my query looks something like this:
{"find" : "terms" , "field" : "node.public_hostname"}
I suppose I need to bring back multiple fields…?
eg:
{"find" : "terms" , "fields" : ["node.public_hostname", "node.name"]}
or similar?
Not sure how to do this.
I tried creating another variable that hung off the first one, like so:
{"find" : "terms" , "field" : "node.name", "query": "node.public_hostname:$Nodes"}
Which works for the first panel, but doesn’t repeat correctly - subsequent panels just show the first one back:
The only way I can see it working so far is to concatenate both values into a single field and then split it out using regex. Is that right?
I created a new field with the node.public_hostname and node.name concatenated. I then set a regex on the Variable that targeted this field to be:
/(?<text>.*):(?<value>.*)/
and I set the panel title as: ${Nodes.__text} but when I select multiple items it just concatenates all the selected variables in all the panel titles rather than repeating the panel and each title having its own correct value. :frowning:
Ok, I think something had cached in my dashboard from last time. I changed the panel title back to ${Nodes} and it all worked as it should.
Cool, glad you got it! And it’s great that you’ve shared your approach so that others in the same boat can hopefully pick it up too. I unfortunately have zero experience with elasticsearch, so would not have been able to contribute anything very meaningful here apart from point you to the regex :).
FWIW, with some other query languages (SQL, GraphQL) there are actually ways to select the “text” and “value” fields separately, without needing to use regex to split a single set of query results. But again, not sure how that plays out with ES.
Hello
i have the same problem and can you explain me how you do to concat both value un a single field in grafana template ?
this query : {“find” : “terms” , “fields” : [“node.public_hostname”, “node.name”]} doesn’t work !
Tanks a lot for you help.
regards
I didn’t get it to work either. In the end I adjusted our beats config to send up an additional pre-concatenated field.
Actually, we’ve since moved away from Grafana. I wanted it for multi-cluster monitoring but it didn’t really work well.
I ended up writing this instead: https://github.com/ndtreviv/elastic-stack-monitoring
Is this also possible for Alert messages?
I exactly followed your description, created a variable in the dashboard section with the desired value from elasticsearch data source.
Then I added the $param to the Custom Labels section, but won’t work. I assume, the Alerting section doesn’t use same variables as the Dashboards section?
How can I specify a variable in Alerting and fill the variable with a elasticsearch query?
