v9.1.1 -
Define an Alias/Label for my Dashboard Variable Dropdown -
Simply add an Dashboard variable via GUI and add my Query that populate my label and value:
import "array"
import "join"
import "influxdata/influxdb/schema"
left = schema.tagValues(bucket: "foobar", tag: "ip")
right =
array.from(
rows: [
{ip: "10.1.1.2", name: "Foobar 2"},
{ip: "10.1.1.6", name: "Foobar 6"},
{ip: "10.1.1.1", name: "Foobar 1"}
join.left(
left: left,
right: right,
on: (l, r) => l._value == r.ip,
as: (l, r) => ({name: r.name, ip: l._value}),
What happened?
In some variation i get thenameas variable dropdown and also as query variable${myVar}. -
that thenameis used for the dropdown and theipas query variable in my dashboard-widgets with a influx source.
