Hi there!
I use custom Dockerfile from packaging/docker/custom/ to build image with Grafana Image Renderer plugin pre-installed (used this article).
Nevertheless, after I trying to run the container with the following image I observe this in logfile:
GF_PATHS_CONFIG='/etc/grafana/grafana.ini' is not readable.
GF_PATHS_DATA='/var/lib/grafana' is not writable.
GF_PATHS_HOME='/usr/share/grafana' is not readable.
You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migration-from-a-previous-version-of-the-docker-container-to-5-1-or-later
t=2021-02-01T21:18:38+0000 lvl=info msg="Starting Grafana" logger=server version=7.3.7 commit=1e261642f4 branch=HEAD compiled=2021-01-14T08:41:57+0000
t=2021-02-01T21:18:38+0000 lvl=info msg="Config loaded from" logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2021-02-01T21:18:38+0000 lvl=info msg="Config loaded from" logger=settings file=/etc/grafana/grafana.ini
I don’t mount folders or volumes. Just run the container with default settings.
Works fine for grafana/grafana:latest image.
Could you please help with the following?
Thanks,
Eugene
