Docker volume mount
Hello Team,
I have recently did mount my docker volume at outside the container (on host machine) path /var/lib/grafana (same like container).
Now I try to restore it with newer image with following cmd →
docker run -d --name=grafana --restart=always -v /var/lib/grafana:/var/lib/grafana 88e7a2eea6d5
I have given fill access to grafana and grafana.db (even “chmod 777 grafana.db”) but in logs its says
"Error: ✗ failed to connect to database: can't check for existence of "/var/lib/grafana/grafana.db": stat /var/lib/grafana/grafana.db: permission denied
GF_PATHS_DATA='/var/lib/grafana' is not writable."
Could you please provide me a solution to restore it with new image?
Hi @karthickmj3110
The error message says that the path /var/lib/grafana is writeable, which is a permission issue.
To fix it provide the correct writeable permission to it using the chmod command and then should work.
