Issue while configuring slack contact points
I have created a slack contact point using Grafana Operator
apiVersion: grafana.integreatly.org/v1beta1
kind: GrafanaContactPoint
metadata:
  namespace: grafana
spec:
  instanceSelector:
    matchLabels:
      dashboards: "grafana"
  type: slack
  settings:
    recipient: "#argocd"
    username: "Grafana"
    icon_emoji: ":grafana:"
    token: ""
  valuesFrom:
    - targetPath: token
      valueFrom:
        secretKeyRef:
          key: SLACK_TOKEN
This creates a slack contact point in grafana.
But when I try to test notification delivery I get this error.
Logs from grafana instance:
logger=ngalert.notifier.slack notifierUID=0cf3251e-23df-4464-b9f6-7c06af020de9 t=2025-12-23T22:32:28.607966088Z level=error msg="Missing receiver"
logger=ngalert.notifier.slack notifierUID=0cf3251e-23df-4464-b9f6-7c06af020de9 t=2025-12-23T22:32:28.60860038Z level=error msg="Missing group labels"
logger=ngalert.notifier.slack notifierUID=0cf3251e-23df-4464-b9f6-7c06af020de9 t=2025-12-23T22:32:28.617948922Z level=error msg="Failed to send Slack message" err="failed to send request: Post \"I1lqTTBPVGhtTUdRdE56Z3lZeTAwTldWbUxXSTJZV0V0T0dJNE5qTTFaVEF4WVRreiMqWVdWekxXTm1ZZyphQmhRUzF0YjS4XvMDXJDKGTQ6n5XZMpQ=\": unsupported protocol scheme \"\""
When I do this manually using UI. It is working as expected.
And when I use this config:
    valuesFrom:
    - targetPath: settings.token
      valueFrom:
        secretKeyRef:
          key: SLACK_TOKEN
I am getting this error:
message: |-
        Contact point failed to be applied for 1 out of 1 instances. Errors:
        - grafana/grafana: updating contact point: [PUT /v1/provisioning/contact-points/{UID}][400] putContactpointBadRequest {"message":"invalid object specification: failed to validate integration \"Slack Contact\" (UID 20a73fd1-9192-4da9-ac41-72946058d2da) of type \"slack\": token must be specified when using the Slack chat API"}
