Is there a supported way to access the dashboard json and upload a changed version?
Hi all
Some years back, I used to download the dashboard json and edit and return it with changes to the server with the API. I also experimented with copying and pasting from the Grafana web UI in
Settings ⚙️ 👉JSON Model.
Issues that I could not solve were clashes with uid and version.
Is there a documented way to do it in the way I want and safely, robustly?
Why not edit directly in the UI?
Its cramped, awkward and in the end not a win for my workflow than jsut using the mouse and clicker UI.
Thanks for any directions on this as I would love to be able to have the option of editing the dashboard json in my favourite environment.
Hey, and thanks for Grafana
E
I have no idea about documentation for this, but I have done exactly the same
thing; created a dashboard manually, downloaded the JSON, and then scripted
changes to that for similar but not identical deployments. I then copy the
resultant JSON file to the path specified in Grafana’s dashboard.yaml file and
reload.
In terms of uid and version, I ensure that uid is unique to the dashboard on
that server (ie: several dashboards on one Grafana instance must have different
uids from each other, but I do not change the uid between versions of the same
dashboard), and I simply increment the version number between updates of each
dashboard. Version numbers have no relationship between different dashboards,
but a new version of a dashboard must have a higher (ie: numerically bigger)
version number than the one it is replacing. The difference doesn’t have to be
precisely one, though - just so long as the new number is bigger than the old
one.
I hope that helps,
Antony.
Thanks a lot for sharing your careful approach Anthony.
When I get down to this, I will follow that and see if I experience more robustness than my experiences when I last braved this. Hopefully it “just works”
I will report back, if anyone else has some nice methodologies or even some scripting for this, that would be nice too :slight_smile:
My best
E
if you use provisiong you could do what you want
Use Grafana dashboard API. BTW: UI uses API as well, so you can use browser console to watch API requests from UI in real life - you will have idea about API endpoints and payloads without reading Grafana API doc. There is also swagger UI, which may help you to develop API queries.
Yes! Would love to succeed provisioning, very elegant.
I also tried this some years ago and stumbled.
Is there any QuickStart guidance that you can share on this.
Following Grafana docs for me are often not great experiences :face_with_hand_over_mouth:
(Another plus one for the comment above from @jangaraj )
check out the provisioning folder for a sample.yaml
but make sure you try things out in a fresh install of grafana locally so as not blow away working dashboards
see this
