I recently discovered Grafana and, so far, reading the docs I couldn’t find a way to solve an issue I’m having. First, let me explain the process and then I’ll explain the problem I’m having.
My company has a platform for content and the visits to its content are logged to Elastic Search. Each visit would create an entry to Elastic Search. See an example below:
"datetime":"2020-06-27T17:12:54.012+01:00",
"CodeLanguage":"eng",
"title":"The United Nations world xxx",
"pdfImportDateInitial_dates":"2020-03-20T12:00:00.000Z",
"id":"0000372882",
"userCountry":"France",
"ipAddress":"xxx.xxx.xxx",
"IsNovelty":"0"
There are more fields but these are the important ones. Each time the title of the content is updated and a new PDF file is added the properties “title” and “pdfImportDateInitial_dates” will have a different value because that’s the title/date at the moment the user is reading the content.
Inside the admin of our system, we offer a Grafana Dashboard with a table panel where the user can see the Title, ID, Language, PDF date and number of visits. As the title and date change, I have the problem you see in the image below:
In the example above I would have to show only one line, with the “xx - newest” title and date and 4 views. It would work as intended if I could retrieve the latest entry from Elastic Search, by datetime desc, and use it’s title and date to fill the respective columns.
Is there any feature of Grafana I could use to achieve this? I’m currently trying transformation but I can’t get a query to return the lastest title and date.
Thanks for any help
