Hello, I have successfully installed Grafana, but due to company policy, I cannot use the internet. Is it necessary to have an internet connection for Grafana 8-10 versions?
I want to control ansible using the rest api plugin, but there is a problem with the existing 7.5 version.
hello @fnzlvj365
It is not necessary, but to install and update plugin versions, it may be necessary, or you can also install via package by downloading directly from the website/github.
Some plugins may require internet access to work, but there are few, I think just Geomap and Wordmap.
Thank you so much for your reply. @bernardolankheet !!!
After rpm installation When I ran Grafana, a warning window appeared.
I thought that progress was not possible in the simple execution stage.
I need to take a closer look at the options in the configuration file.
thank you!!!
