Dear Grafana Support Team,
I am currently working with Grafana in an environment where the client PC does not have access to the internet. When I attempt to access Grafana on a PC with no internet connection, I encounter the following error:
“If you’re seeing this, Grafana has failed to load its application files.”
However, when I access Grafana from a machine with internet access, everything works perfectly, and the dashboard loads as expected.
I would like to know if it is possible to use Grafana in an offline environment where the client PC cannot access the internet. Specifically, I’m wondering if there’s a way to resolve the issue of Grafana failing to load its application files when no internet connection is available. Are there any configuration settings or solutions to ensure that Grafana can function properly in such an environment?
I would appreciate any guidance or advice on how to make Grafana work in an offline environment.
Thank you for your time and support.
