Install and configur grafana on Windows that has no internet connection
    Download the zip file grafana-enterprise-10.2.1.windows-amd64
    On windows 10 Enterprise LTSC without internet connection
    Running Grafana on Windows using InfluxDB as datasource
    Follow the step proposed in https://www.youtube.com/watch?v=NlmArL07Vgc
  • What happened?
    When enter http://localhost:3000 in firefox (87.0 (64-bit)), it displays:
If you’re seeing this Grafana has failed to load its application files
  1. This could be caused by your reverse proxy settings.
  2. If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If not using a reverse proxy make sure to set serve_from_sub_path to true.
  3. If you have a local dev build make sure you build frontend using: yarn start, or yarn build
  4. Sometimes restarting grafana-server can help
  5. Check if you are using a non-supported browser. For more information, refer to the list of supported browsers.
    I expect to connect grafana
    Can’t attach .ini file
    Please find the logs in attachment
    I followed the video : https://www.youtube.com/watch?v=NlmArL07Vgc
    I also created influxdb.yaml in C:\Grafana\conf\provisioning\datasources as following:
# # config file version
apiVersion: 1
# # list of datasources that should be deleted from the database
#deleteDatasources:
#   - name: Graphite
#     orgId: 1
# # list of datasources to insert/update depending
# # on what's available in the database
datasources:
#   # <string, required> name of the datasource. Required
# - name: Graphite
  - name: InfluxDB
#   # <string, required> datasource type. Required
#   type: graphite
    type: influxdb
#   # <string, required> access mode. direct or proxy. Required
    access: proxy
#   # <int> org id. will default to orgId 1 if not specified
    orgId: 1
#   # <string> url
    url: http://localhost:8086
#   # <string> database user, if used
#   user:
#   # <string> database name, if used
    database: "CESDatabase"
#   # <bool> enable/disable basic auth
    basicAuth: false
#   # <string> basic auth username
#   basicAuthUser:
#   # <bool> enable/disable with credentials headers
#   withCredentials:
#   # <bool> mark as default datasource. Max one per org
    isDefault: true
#   # <map> fields that will be converted to json and stored in json_data
#   jsonData:
#      graphiteVersion: "1.1"
#      tlsAuth: true
#      tlsAuthWithCACert: true
#      httpHeaderName1: "Authorization"
#   # <string> json object of data that will be encrypted.
#   secureJsonData:
#     tlsCACert: "..."
#     tlsClientCert: "..."
#     tlsClientKey: "..."
#     # <openshift\kubernetes token example>
#     httpHeaderValue1: "Bearer xf5yhfkpsnmgo"
#   version: 1
#   # <bool> allow users to edit datasources from the UI.
    editable: true
Welcome @yanggao
Let’s first start things with a simple install
  1. Go to
  1. Download the zip file
  2. Extract the zip file
  3. Without changing any .ini file go to the bin and run grafana-server.exe
  4. Go to localhost:3000
Hi @yosiasz ,
Thank you very much for your response. I followed the steps and then started Grafana, but I encountered the error attached. Please note that my Windows PC does not have an internet connection.
