Is alertname a reserved label?
After upgrading from community version from 8.1.1 to 9.1.4, many warnings like
level=warn msg="rule declares one or many reserved labels. Those rules labels will be ignored" labels="alertname=View refreshing"
are displayed in the log. It seems that “alertname” has become a reserved label, however I cannot find any documentation on this, e.g. on Grafana Reserved Labels. Can you bring any light on this? Would it be safe to remove the labels?
noticed the same in my setup after migration a lot of warnings like this.
I’m seeing the same thing. Unsure if I should just remove the labels.
Related to 9.1.6 warn - rule declares one or many reserved labels. Those rules labels will be ignored · Issue #55670 · grafana/grafana · GitHub
