I cannot remove reserved labels in grafana from the template
Hello @hritikjaiswal1261,
Please check next links for removing grafana reserved labels from alerts:
If you are using Grafana OSS or Grafana Enterprise you need to edit configuration file which is by default on path:
/etc/grafana/grafana.ini
and set:
[unified_alerting.reserved_labels]
disabled_labels=grafana_folder
after that you need to restart grafana-server (e.g. for RHEL based OS):
systemctl restart grafana-server.service
Hope this helps.
Best regards,
ldrascic
