Grafana v10.4.2 - What are you trying to achieve?
The same result of data aggregated via interval variable. - How are you trying to achieve it?
Type of my metrics is RANGE.
I’ve created INTERVAL varbiable with default values such 1,2,5,10,15 etc minutes - What happened?
When I’m using this variable in my Time-Series graph I have two different results:
1 minute interval shows correct value with all of my bars,
but
5 minutes interval deleted one of my graph - I’m assuming that should be displayed as well but in different time span 5 ; 10 ; 15 minutes in graph but result should be aggregated not deleted. I do not know why it works like that. - What did you expect to happen?
I expect that If I have results from for example 4 bars when I’m usign 1 minute interval
Those results should be the same but aggregated on 5 minutes interval. - Can you copy/paste the configuration(s) that you are having problems with?
1 minute interval data:
5 minutes interval data:
Internal varbiable:
