When viewing time frames greater than 7 days, my graphs show data points that are too close together to be legible.
In a 30 day view, Grafana sets the interval to 1h. This is the case when I do not set a minimum interval in my data source and when I set the minimum interval to 1h.
I attempted to use an interval and custom variable, but using template variables cause alerts to be disabled.
Is there any way to limit each graph to show only 30 data points?
My example query.
WITH table_data_epo AS ( SELECT
event AS metric,
cast(count(*) AS int) AS value,
$__timeGroup(created_at, $time_interval, 0) AS epo
FROM
public."Metric"
GROUP BY
metric,
epo
ORDER BY
epo DESC),
table_data_timestamp AS (
SELECT
metric,
value,
to_timestamp(epo) AS time
FROM
table_data_epo)
SELECT
metric,
value,
time
FROM
WHERE
$__timeFilter(time)
