My Grafana, in the graphs, only shows an interval of 3 months, although there is information available.
Is it necessary to configure any parameter to remove this time limitation?
Any dashboard I’ve set up only shows 3 months.
Thanks in advance
welcome to the
community @packticho!
You should be able to see more than 3 months of data if it’s available from the datasource. Can you share more information with the community about your dashboard:
- which datasource are you using in your graphs?
export and share the dashboard json if possible?
- include a screenshot of your dashboard, do you see more data in explore versus your graph panel?
