Introduction:
In today’s digital landscape, data visualization plays a crucial role in gaining insights and making informed decisions. This report outlines the process of integrating React filters with a Grafana dashboard for map visualization using PostgreSQL database and Express.js. By seamlessly connecting these components, users can dynamically filter data displayed on the map view, enhancing the overall user experience and decision-making capabilities.
Architecture:
PostgreSQL Database: Stores the data used for visualization.
Express.js: Acts as a backend server to retrieve data from the PostgreSQL database and pass it to the React frontend.
React: Frontend framework responsible for rendering the user interface and managing filter selections.
Grafana Dashboard: Utilized for map visualization with the “Loop Monthly Sales” dashboard.
Steps:
1. Data Preparation: Create a PostgreSQL database and import the required dataset.
2. Grafana Dashboard Setup: Create a new dashboard in Grafana and configure the map visualization using the “Loop Monthly Sales” dashboard.
3. React Frontend: Implement React components for filters, such as Hub Code, Plant, Customer, etc. Use Axios or Fetch API to make requests to the Express.js backend for filter data. Integrate the React filters with the Grafana dashboard filters by passing filter values via URL parameters.
4. Express.js Backend: Develop an Express.js server to handle requests for data retrieval from the PostgreSQL database. Write SQL queries to fetch data based on filter selections. Expose API endpoints to serve data to the React frontend.
5. Dynamic Visualization: As users select filter options in the React frontend, update the URL parameters to reflect the selected filters. Grafana dashboard automatically updates the map visualization based on the passed filter values.
6. Testing and Optimization: Test the integration thoroughly to ensure seamless interaction between React filters and the Grafana dashboard. Optimize the application for performance and user experience.
Final Output:
The final output is a web application where users can interact with React filters to dynamically filter data displayed on the map visualization provided by the Grafana dashboard. As users make selections in the React filters, the map view updates in real-time to reflect the filtered data, empowering users to explore and analyze data effectively.
Conclusion:
Integrating React filters with Grafana dashboard for map visualization offers a powerful solution for data exploration and analysis. By combining the strengths of PostgreSQL, Express.js, React, and Grafana, organizations can build robust data visualization platforms that enable users to derive actionable insights from complex datasets. This integration enhances decision-making processes and fosters a data-driven culture within the organization.
