Insert a bar in a graph with curves
I am new to using grafana and would like some advice.
In a graph, I record the temperature of my indoor thermostat, the outdoor temperature and the ON / OFF (0/1) operating state of my heat pump.
I would like to be able to display the state of the heating (0/1) in the form of a transparent bar, which would take the full height of the graph (0/100%), while allowing to continue to see the two temperature curves ?
The abssices axis indicates the passing time.
The y-axis of my graph, indicates the temperatures in for the moment varies from 0 to 22 °
Kind regards,
Philippe
welcome to the :grafana: forum, @pce5962
are you talking about making a graph like this:
https://play.grafana.org/d/000000012/grafana-play-home?orgId=1&viewPanel=4
You can change the graph style using field overrides :+1:
Or perhaps this?
