InfluxDB v2 Sample Dashboards/Queries
Are there any sample dashboards or queries that would show how to create most common types of graphs (e.g. memory usage, cpu, etc.). All dashboards I’ve seen are still using InfluxDB 1.x. I’m looking for some examples on how to properly create legend labels and aggregate data for most common/basic use cases (e.g. memory/cpu usage per docker container on a single graph, labeled by “container_name”).
Thanks,
Jerry
Have you looked at the InfluxDB2 templates?
I have these setup in the InfluxDB2 UI and it should be fairly simple to port over the supplied Flux queries to use in Grafana.
