Grafana InfluxDB v2 Dashboard
Hi all,
Can someone help me with a proper dashboard that works with flux & influxdb v2.
I have found these three from the official grafana website, but they are quite basic.
I would like to have something similar to this one
K6 Dashboard | Grafana Labs .
Any advices/links are welcomed and really appreciated!
please share your data sample as csv or line protocol
Hi @yosiasz , Thank you for the quick response.
Would you please elaborate a bit more here?
What exactly do you need - a sample from the influxDB with my data or something else?
Also another question, if I want to use xk6, can I still use influxDB v1 or I need v2?
Second I read that FLUX will be deprecated and will not be supported.
So does it mean that I should go directly with influxdb v3 and influxQL?
I don’t have any data to migrate so, no effort there.
yes please a sample from your data. flux or ingluxql is up to you. we decided mysql
