Inconsistent sorting / order
I’m experiencing an inconsistent behavior with data formatting in Grafana when using a custom column order in my Flux query. I hope someone can shed some light on this issue.
My query looks like this:
from(bucket: "data")
  |> range(start: -21d)
  |> filter(fn: (r) => r._measurement == "co2SensorData" and r.co2DeviceName == "${co2DeviceName}")
  |> filter(fn: (r) => r._field == "temperature" or r._field == "humidity" or r._field == "light" or r._field == "co2" or r._field == "voc" or r._field == "vdd" or r._field == "motion")
  |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
  |> map(fn: (r) => ({
      _time: r._time,
      co2DeviceName: r.co2DeviceName,
      temperature: r.temperature,
      humidity: r.humidity,
      light: r.light,
      co2: r.co2,
      voc: r.voc,
      vdd: r.vdd,
      motion: r.motion
  |> yield(name: "results")
The issue I’m facing is that when I use this query to specify a custom column order, Grafana inconsistently formats my data. However, when I don’t specify an order and use the default query, the formatting remains consistent.
Thank you in advance for your help!
Please specify order of what exactly in Grafana is a problem. How it is query formatted,… Generally, provide reproducible example. There can be many variables in your case (e. g. Grafana version) and you specified none of them.
10.4
Using the Stat panel (in a repeating row by variable ${vocDeviceName}, I wanted to change the order in which the data is displayed from the Grafana default order.
Using this query:
  |> range(start: -21d)
  |> map(fn: (r) => ({
      _time: r._time,
      light: r.light,
      co2: r.co2,
      voc: r.voc,
      vdd: r.vdd,
      motion: r.motion
What happened?
Upon trying multiple other types of queries including this one, each time the page is refreshed and a repeating panel is rendered, the order is completely different each time.
I expected the data in the panels to return the mapped sorted order from the query.
No, the query executed fine.
Screenshot to help visualize
Default Grafana Order:
Custom Order Query:
You have not specified any explicit sorting that I can see
Is this not explicitly sorting the data? Returning a mapped of the results in the order I want.
So that is sequence of columns
Sort is a whole different . meaning in the data world
But that said I see your issue
