I’m using Grafana 9.2.5. -
I have created a table using Flux. In this querie i created one column per month and it looks like this:
My problem is that Grafana is sorting the columns in a weird way.
In this table i have the column for this month sorted on the left side of the panel. But the other months of 2023 are sorted to the right.
The Query will create a new column for every new month.
Is it possible to sort the columns without using the transformation “Organize Fields”?
I dont want to sort the columns manualy every month.
Hi @patse, ![]()
Thanks for opening this issue.
Can you please send us this data (the one you shared in the screenshot) as a CSV so that we can test it out and see how it can be solved?
Hey @usman.ahmad ,
i will need a few days to get the permission to share the csv.
Hey, I have the same problem. I also want to know how to sort the columns.
Did you get permission to share the CSV?
