my query result is:
but in grafana display is:
and what can i do make the same!
thank you!
my query result is:
thank you!
If I understand your question correctly you want the result to be sorted in the same way? In Grafana, just click on the column header to sort on that column ascending, click one more time to sort descending, click one more time to remove sorting.
Please let me know if this helps
Marcus
