I build panel in grafana with some query and expressions for it.
Query is a metric of successful requests rate for different applications, it has only one label - applications
Now i got results in gauge bar. In the screenshot you can see results, but not sorted.
How to sort results, and output only first 3 of them?
I can change panel type to whatever that solves my task. I tried to get rid of expressions and use only query and apply sort to it. But using only query without expressions doesn’t fit my needs
