i have a bar gauge dashboar that has multiple queries and i want to order them by value
It has multiple queries such as this:
All the data comes from influx.
I tried with the sort by transformation but it doesnt make sense for my case:
Can you join those 2 queries using Join by field first then apply sort?
how do i do that? I have 8 queries
do they have a shared/common field you can use?
Maybe i have an older version cause i dont have that transformation ![]()
Is there another way?
If it’s possible to redesign InfluxDB side, I would go that way. I.e. to store everything in one bucket, using different tags. And have only one query to get all measurements.
exactly! @coricajuan5 your design approach is exposing you to this challenge.
