Grafana v11.5.2 (598e0338d5) as a Docker Container on Alma Linux
- What are you trying to achieve?
Have the output of a mySQL query sorted by single total power usage of the devices, shown as a Bar Chart.
- How are you trying to achieve it?
I tried sorting inside the query, splitting into multiple queries, checking if a transformation will work and read if the legend can be used as sorting parameter - but I can’t seem to get it working.
- What happened?
The data for each device is correctly displayed - but ordered as specified in the query.
As mentioned above - I really want the data sorted dynamically. I have the same query for yearly, monthly and daily visualization - manually sorting is not an option.
- Can you copy/paste the configuration(s) that you are having problems with?
This is the query I currently have without trying to sort it per device.
SELECT
STR_TO_DATE(CONCAT(year, '-01-01'), '%Y-%m-%d') AS time,
SUM(CASE WHEN device = 'Server-Rack' THEN power_usage_kwh ELSE 0 END) AS `Server-Rack`,
SUM(CASE WHEN device = 'Walking-Pad' THEN power_usage_kwh ELSE 0 END) AS `Walking-Pad`,
SUM(CASE WHEN device = 'Waschmaschine' THEN power_usage_kwh ELSE 0 END) AS `Waschmaschine`,
SUM(CASE WHEN device = 'Kuehlschrank' THEN power_usage_kwh ELSE 0 END) AS `Kuehlschrank`,
SUM(CASE WHEN device = 'Schreibtisch-1' THEN power_usage_kwh ELSE 0 END) AS `Schreibtisch-Alex`,
SUM(CASE WHEN device = 'Steckdose-Bad' THEN power_usage_kwh ELSE 0 END) AS `Steckdose-Bad`,
SUM(CASE WHEN device = 'Fernseher' THEN power_usage_kwh ELSE 0 END) AS `Fernseher`,
SUM(CASE WHEN device = 'Schreibtisch-2' THEN power_usage_kwh ELSE 0 END) AS `Schreibtisch-Andrea`,
SUM(CASE WHEN device = 'Gefrierschrank' THEN power_usage_kwh ELSE 0 END) AS `Gefrierschrank`,
SUM(CASE WHEN device = 'Amps' THEN power_usage_kwh ELSE 0 END) AS `Amps`
FROM power_usage_db.power_usage
GROUP BY year
ORDER BY year ASC;
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No.
- Did you follow any online instructions? If so, what is the URL?
Did not find any promising instructions - even wasted half a day with ChatGPT ![]()
Thank you very much in advance for any help!
