Problem: Can’t get Grafana to show query result in stacked bar chart:
MySQL query is like:
SELECT
projectName,
sum(case when buildResult = 'SUCCESS' then 1 else 0 end) AS SuccessCount,
sum(case when buildResult = 'FAILURE' then 1 else 0 end) AS FailureCount,
sum(case when buildResult = 'ABORTED' then 1 else 0 end) AS AbortedCount,
sum(case when buildResult = 'UNSTABLE' then 1 else 0 end) AS UnstableCount
FROM
executor_data
WHERE
executorNode = 'ABCD'
GROUP BY projectName
and MySQL Returns:
+--------------------------------+--------------+--------------+--------------+---------------+ | projectName | SuccessCount | FailureCount | AbortedCount | UnstableCount | +--------------------------------+--------------+--------------+--------------+---------------+ | End User A | 87 | 53 | 9 | 0 | | EUA | 282 | 139 | 2 | 3 | | SP | 12 | 3 | 0 | 0 | | NULL | 0 | 0 | 0 | 0 | | FIT | 4 | 0 | 0 | 0 | +--------------------------------+--------------+--------------+--------------+---------------+ 5 rows in set (0.00 sec)
I modified my query for Grafana like the following:
SELECT $__timeGroupAlias(time_stamp,$__interval), projectName as metric, sum(case when buildResult = 'SUCCESS' then 1 else 0 end) AS SuccessCount, sum(case when buildResult = 'FAILURE' then 1 else 0 end) AS FailureCount, sum(case when buildResult = 'ABORTED' then 1 else 0 end) AS AbortedCount, sum(case when buildResult = 'UNSTABLE' then 1 else 0 end) AS UnstableCount FROM executor_data WHERE $__timeFilter(time_stamp) AND executorNode = '$executorNode' GROUP BY metric, time_stamp ORDER BY $__timeGroup(time_stamp,$__interval)
What I need:
I need Grafana to show a bar on Grafana for each of the projects consisting of counts on Success/Failure/Aborted/Unstable.
Grafana Would return the following Graph, But it is not stacked and grouped by project names.
I would appreciate if someone could help me out here, and let me know what is it that I am doing wrong!
