9.5.3 deployed on k8s -
I am trying to have such chart. I got 6 metrics(say A_SUCCESS, A_FAIL, B_SUCCESS, B_FAIL, C_SUCCESS, C_FAIL) They are prometheus counters. I want have 3 bars A B and C. SUCCESS and FAIL are stacked like the graph shown. -
The metrics looks like
sum(increase(A_SUCCESS{name="somename"}[$__range:10s] @ ${__to:date:seconds}))
sum(increase(A_FAIL{name="somename"}[$__range:10s] @ ${__to:date:seconds}))
for a bar chart, I cannot get rid of the time series x axis. But I want x axis to be A B and C and y axis to be the value of
sum(increase(A_FAIL{name="somename"}[$__range:10s] @ ${__to:date:seconds})) the query result.
For Bar Gauge,
But I did not see any stack option so I cannot the SUCCESS and FAIL stacked in one bar.
What happened?
The expected graph is from this discussion. The post seems have a SQL db but i am using prometheus
