I’am using Grafana v10.4.0 version.
I have an issue with creating a bar gauge-ish or bar chart (vertical one).
I think there are around 11 metrics and I want to create 2 bars with all of those metrics.
For Example, I want to use:
Metric A, Metric B, and Metric C for Bar number 1 and show as a stacked bar with all of those values from each metric.
My goal is to achieve 2 bars with all metrics but those bars should show every value from each metric. What’s more, I’m also using the variables for filtering data (but idk if it is important or not).
I managed to create separate bars by aggregating those metrics into two different bars (without stacking) using the transformation: “Add field from calculation” and “Filter fields by name” but I Don’t have any idea how to change/create a different one with a stacked bar.
Do you have any idea how to do it?
It is very important to achieve vertical bar-gauge with two stacked bars.
