Grafana 8.3.1 (I tried with 9.1.7 as well) -
I have different Counter prometheus metrics per Objects.
I want to create a Stacked Bar Chart over the time, an “Acitvity per Day Panel”.
A counter is incremented each time an object is used on back end side.
My data looks like :
object_usage_count_total{object="tc 1"} 2.0
object_usage_count_total{object="tc5"} 3.0
- How are you trying to achieve it?
round(increase(object_usage_count_total[5m]))
I’m using this prometheus query with Min Step 5m (I’m using 5m for test purpose even if my goal is 1d)
And I’ve selected Stacked Bar Chart
- What happened?
I have the following result at this moment :
Which is pretty nice, it looks like what I want, except that the first usage of an object is never shown.
For this example I used 3 time TC5 and 2 time TC1. And as we can see there’s a total of 2 activity for TC5 and 1 activity for TC1.
I think that I know what is the origin of this issue.
When an object is used for the first time, the created counter have the value 1 as we can see on the image below.
The value 0 never exists for this counter, so for the “increase” method the value didn’t increase by one.
I thought of initializing the counter to 0 before, but the problem is that a new object can be created at any moment, and when it’s created, it is automatically used once. The state “used 0 time” doesn’t really exist.
I have 2 questions:
Is it considered as a bug or is the behavior of “increase” like this on purpose ?
Do you have a solution that might work in my case ?
Thanks
(Maybe I’m on the wrong category sorry, I didn’t found anything related to “increase”)
Nothing -
Yes, just saw on every “Activity per day” topics that “increase” is what I need.
But no specific URL to provide.
