Sorting after transposing the data
    11.4.0-79146
    I’ve a time series data that has time and percentage as fields. This is a sample query - avg by ()(kubernetes_io:container_cpu_request_utilization{…}) * 100. I’ve such 14 queries that return the data as time and percentage. Each query returns a single result as I’ve set it to return ‘Instance’. I am transposing them so time field becomes column name. I need to sort on this column. Since the column name is variable when I specify this in transformation initially it works at that instance, but as soon as I run it after some time the sorting goes away.
    I’m using transpose to covert the rows to column for display using transformations. After doing this I’m trying to sort on columns, but since the value of column changes frequently the sorting goes away. I see the results as un-sorted.
  • What happened?
    The results are unsorted.
    I want to sort the results.
    “transformations”: [
    “id”: “merge”,
    “options”: {}
    “id”: “transpose”,
    “options”: {}
    “id”: “formatString”,
    “options”: {
    “outputFormat”: “Substring”,
    “stringField”: “Field”,
    “substringStart”: 7
    “id”: “sortBy”,
    “options”: {
    “fields”: {},
    “sort”: [
    “desc”: true,
    “field”: “1732561753928”
    No errors
    None
