How to order columns in Tables
Is it possible to order the columns in a Grafana Table?
I have a Table (sourced from InfluxDB) but the columns are in a «wrong» order… I tried changing the order of the Group By clause in the InfluxQL but I get the exact same results.
The order of columns in Table panel is deterimed by the data if the data is in Table format, then it’s up to your InfluxDB table queries. If that is not deterministic or you lack control, then you need to open feature request with InfluxDB.
