I’m not sure what can cause it, but I’ve different panel ID between GUI and (API & DB). I’ve done restart of the grafana service as well to be sure. This is happening for 6 out of 135 graphs/panels.
In GUI, I click view on the relevant graph and check the value of the panelId variable. Its different from the “ïd” of the API data returned for the same graph. Ive got the content of the grafana.db sqlite db and I can find the “id” for the graph corresponding to the API version. The GUI panelID is not present anywhere in the API output or sqlite dashboard output.
Grafana v5.4.2 (d812109)
Thanks!
Vit
