Get All of the panel Ids from Dashboard using Grafana DashBoard API
    v7.5.10 (e72061a129)
    We are trying to retrieve all of the panel ids that are on a dashboard via the restful web service.
    Using HTTP API
  • What happened?
    No
Hi @ddavismomemtum,
This ought to do it:
curl -s -H "Authorization: Bearer ${KEY}" \
"${YOUR-GRAFANA-URL}/api/dashboards/uid/${DASH-UID}" | \
jq '.dashboard.panels[].id'
I would also check out this much larger conversation about writing bash scripts to import export dashboard json.
Also, if you used a dashboards-as-code approach and checked your dashboards into version control, then you wouldn’t need to rely on the api :+1:
Thanks for the response. I think my main problem is that there is no id field in the result object.
Below is an example of the dashboard node of the return object. Panels does not seem to have an id field.
“dashboard”: {
“id”: 94,
“panels”: [
“dashLength”: 10,
“datasource”: “Graphite Remote”,
“description”: “west01.voip.evolveip.net”,
“gridPos”: {
“h”: 9,
“w”: 12,
“x”: 0,
“y”: 0
“lines”: true,
“linewidth”: 1,
“nullPointMode”: “connected”,
“targets”: [
“refId”: “A”,
“target”: “alias(dctnms01.west01.PING.rta, ‘Ping RTA’)”,
“textEditor”: false
“title”: “west01.voip.evolveip.net PING”,
“type”: “graph”,
“xaxis”: {
“buckets”: null,
“mode”: “time”,
“name”: null,
“show”: true,
“values”:
“yaxes”: [
“format”: “ms”,
“label”: “RTA”,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“tags”: [
“west01”,
“checkmk”,
“country: US”,
“carrier: Evolve-LasVegas-SBCs”,
“description: west01.voip.evolveip.net
“time”: {
“from”: “now-6h”,
“to”: “now”
“timezone”: “browser”,
“title”: “west01.voip.evolveip.net”,
“uid”: “qWVHP27Mz”,
“version”: 1
@ddavismomemtum @anon70503803 did you figure out why your panel id is missing? I am running to a similar issues with a graph panel not showing when running:
but showing up in the json model.
I understand that it has been a while, but I was wondering if you recall whether you were able to resolve the issue and, if so, how did you go about it? I am currently facing the exact same problem with Grafana v9.5.2
