Good morning everyone!
I have a use case where I’d like to be able to filter a table contents based on a panel and dashboard id of the current page. I’ve had a good look a the help, googled my way around and the only thing I can think of at this point is to parse the dashboard JSON for a particular board to extract its ID and the panel IDs.
Firstly, is there a local variable that is easy to extract the dashboard ID from?
Secondly, if there isn’t where would I look for an example of how to extract the current dashboard ID from the dashboards JSON?
Any suggestions welcome, thanks for your time helping out.
