In canvas img/bg svg img not show in 12.2.1 version
hello
in grafana canvas plugin img/bg img not show i used rocky linux 10 os 12.2.1 grafana enterprises version.
but when i add ip/public it will show , i want default path to show background img please help to suggest any solution.
hello grafana users, please suggest any solutoin??
Where is the svg files saved?
usr/share/public/img/bg
When i check in inspect
Grafana take path like this
build/img/bg
When i remove build from inspect img show correctly, how can remove this build and fix this issue.
Graphana 12.3.3 still with this bug.We need to copy the images and svg in the build\img\bg path to show the background
