I have a running chain: data-source, influxdb and grafana.
An application requests data from the data-source and write these data into influxdb.
Now I have the idea to make some optimization steps.
One point is to write only changed values into the database:
Like in this pattern
public class X
private int x = 1;
public void setX(int proposedValueForX)
if(proposedValueForX != x)
writeToInfluxDB();
x = proposedValueForX;
On the grafana site, I use this query:
from(bucket: "grafanaBucket")
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) =>
r._measurement == "DEVICE1" and
r.COMMON == "VALUE1"
|> set(key: "_field", value: "")
|> set(key: "COMMON", value: "DEVICE 1")
|> aggregateWindow(every: v.windowPeriod, fn: last)
But with this query, I get the value of the last marked time.
On a graph, I need to show the last changed value periodically independent of the last inserted time/value pair.
Is there a known approach for that?
Thx in advance
