Image Rendering Failed
I’m still trying to work through this issue, Discord alert graph image is wrong.
I have installed grafana-image-render and all its dependencies, but am now seeing a new issue. I get a straight up error when trying to render images.
I’m currently getting this error now: https://i.imgur.com/s3e7E8w.png
I’m using SSL, root url set as, https://ops.site.net/stats. Domain set as, ops.site.net.
Logs:
t=2020-01-27T13:37:11-0600 lvl=info msg=“Renderer plugin started” logger=rendering grpcHost=127.0.0.1 grpcPort=40993.000 chromeBin=/var/lib/grafana/plugins/grafana-image-renderer/chrome-linux/chrome ignoreHTTPSErrors=false timestamp=0001-01-01T00:00:00.000Z
t=2020-01-27T13:37:50-0600 lvl=eror msg=“Browser request failed” logger=rendering url=“https://localhost:3100/d-solo/bw7jrSyWk/net-dashboard?orgId=1&refresh=5s&from=1580132269383&to=1580153869383&var-DS_PROMETHEUS=Prometheus&var-host=localhost:9104&var-job=prometheus&var-name=ZN-Zeus&var-node=localhost&var-port=9100&var-hostname=ZN-Zeus&var-nodexp=localhost:9100&var-maxmount=%2F&var-namexp=&var-env=&var-aphost=localhost&var-aport=9117&var-interval=1s&panelId=33&width=1000&height=500&tz=America%2FChicago&render=1” method=GET timestamp=0001-01-01T00:00:00.000Z
t=2020-01-27T13:37:50-0600 lvl=eror msg=“Render request failed” logger=rendering url=“https://localhost:3100/d-solo/bw7jrSyWk/net-dashboard?orgId=1&refresh=5s&from=1580132269383&to=1580153869383&var-DS_PROMETHEUS=Prometheus&var-host=localhost:9104&var-job=prometheus&var-name=ZN-Zeus&var-node=localhost&var-port=9100&var-hostname=ZN-Zeus&var-nodexp=localhost:9100&var-maxmount=%2F&var-namexp=&var-env=&var-aphost=localhost&var-aport=9117&var-interval=1s&panelId=33&width=1000&height=500&tz=America%2FChicago&render=1” error=“Error: net::ERR_CERT_COMMON_NAME_INVALID at https://localhost:3100/d-solo/bw7jrSyWk/net-dashboard?orgId=1&refresh=5s&from=1580132269383&to=1580153869383&var-DS_PROMETHEUS=Prometheus&var-host=localhost:9104&var-job=prometheus&var-name=ZN-Zeus&var-node=localhost&var-port=9100&var-hostname=ZN-Zeus&var-nodexp=localhost:9100&var-maxmount=%2F&var-namexp=&var-env=&var-aphost=localhost&var-aport=9117&var-interval=1s&panelId=33&width=1000&height=500&tz=America%2FChicago&render=1” timestamp=0001-01-01T00:00:00.000Z
t=2020-01-27T13:37:50-0600 lvl=eror msg=“Rendering failed.” logger=context userId=4 orgId=1 uname=zeus error=“Rendering failed: Error: net::ERR_CERT_COMMON_NAME_INVALID at https://localhost:3100/d-solo/bw7jrSyWk/net-dashboard?orgId=1&refresh=5s&from=1580132269383&to=1580153869383&var-DS_PROMETHEUS=Prometheus&var-host=localhost:9104&var-job=prometheus&var-name=ZN-Zeus&var-node=localhost&var-port=9100&var-hostname=ZN-Zeus&var-nodexp=localhost:9100&var-maxmount=%2F&var-namexp=&var-env=&var-aphost=localhost&var-aport=9117&var-interval=1s&panelId=33&width=1000&height=500&tz=America%2FChicago&render=1
t=2020-01-27T13:37:50-0600 lvl=eror msg=“Request Completed” logger=context userId=4 orgId=1 uname=zeus method=GET path=/render/d-solo/bw7jrSyWk/net-dashboard status=500 remote_addr=“2605:6000:1026:867b:5c6e:9d26:bb8:3da2, 2605:6000:1026:867b:5c6e:9d26:bb8:3da2” time_ms=323 size=1728 referer=“https://ops.site.net/stats/d/bw7jrSyWk/net-dashboard?orgId=1&refresh=5s
Hi mates,
I’m facing same issue. My grafana app is hosted in private network with “development” hostname.
I have certificate for publik dns record, which makes my grafana available outside private network. The problem is that do not have ablity include production hostname into cetificate.
Am I able change security levels or something like for render plugin?
Hi Did you find the solution?
I have same problem
and my grafana version is 9.0.1
Hello @zeusnet and everybody else
This seems to be related to a known issue which was reported in this post that also contains a solution:
Hope it helps
