Image Renderer plugin uses Localhost rather than defined domain
Grafana 7.0 on Windows
Image Renderer 2.0.0
This might be user error, but my renderer plugin keeps trying to use https://community.grafana.com rather than mydomainnamehere:3000
This results in a certificate name mismatch. I am pretty sure my config files are correct, as the “Share Panel” function in grafana shows the correct domain name.
Here are the logs entries i have (I had to pull the scheme from the links because discourse wont let me create a post with more than two links)
t=2020-05-21T14:04:27-0500 lvl=info msg=Rendering logger=rendering renderer=plugin path=“d-solo/2s5AeqgMz/adfs-dashboard?orgId=1&from=1590065403745&to=1590087003745&panelId=4&width=1000&height=500&tz=America%2FChicago”
t=2020-05-21T14:04:27-0500 lvl=dbug msg=“Calling renderer plugin” logger=rendering renderer=plugin req="url:“community.grafana.com/d-solo/2s5AeqgMz/adfs-dashboard?orgId=1&from=1590065403745&to=1590087003745&panelId=4&width=1000&height=500&tz=America%2FChicago&render=1” width:1000 height:500 deviceScaleFactor:1 filePath:“C:\\Program Files\\GrafanaLabs\\grafana\\data\\png\\Ay6FLmnoZZ8UhTL9uFhO.png” renderKey:“6y3SJYFNVsobIh7dV7f5YqU4QbJ7YFEg” domain:“localhost” timeout:60 timezone:“America/Chicago” headers:<key:“Accept-Language” value:<values:“en-US,en;q=0.9” > > "
t=2020-05-21T14:04:28-0500 lvl=eror msg=“Browser request failed” logger=plugins.backend pluginId=grafana-image-renderer url=“community.grafana.com/d-solo/2s5AeqgMz/adfs-dashboard?orgId=1&from=1590065403745&to=1590087003745&panelId=4&width=1000&height=500&tz=America%2FChicago&render=1” method=GET failure=net::ERR_CERT_COMMON_NAME_INVALID
t=2020-05-21T14:04:28-0500 lvl=eror msg=“Render request failed” logger=plugins.backend pluginId=grafana-image-renderer url=“community.grafana.com/d-solo/2s5AeqgMz/adfs-dashboard?orgId=1&from=1590065403745&to=1590087003745&panelId=4&width=1000&height=500&tz=America%2FChicago&render=1” error=“Error: net::ERR_CERT_COMMON_NAME_INVALID at https://community.grafana.com/d-solo/2s5AeqgMz/adfs-dashboard?orgId=1&from=1590065403745&to=1590087003745&panelId=4&width=1000&height=500&tz=America%2FChicago&render=1”
t=2020-05-21T14:04:28-0500 lvl=eror msg=“Rendering failed.” logger=context userId=3 orgId=1 uname=JohnDaley error=“Rendering failed: Error: net::ERR_CERT_COMMON_NAME_INVALID at community.grafana.com/d-solo/2s5AeqgMz/adfs-dashboard?orgId=1&from=1590065403745&to=1590087003745&panelId=4&width=1000&height=500&tz=America%2FChicago&render=1”
t=2020-05-21T14:04:28-0500 lvl=eror msg=“Request Completed” logger=context userId=3 orgId=1 uname=JohnDaley method=GET path=/render/d-solo/2s5AeqgMz/adfs-dashboard status=500 remote_addr=10.1.56.66 time_ms=450 size=1723 referer=“winmgmt:3000/d/2s5AeqgMz/adfs-dashboard?orgId=1”
I was having the same problem. Try setting the following in /etc/grafana/grafana.ini:
[plugin.grafana-image-renderer]
rendering_ignore_https_errors = true
That worked for my setup using Grafana 7.0 and Image Renderer 2.0.
This helps! Thank you!
Its nice to know i’m not the only one seeing this. Ideally - and im sure you’d agree - the image renderer plugin didnt use localhost, but this is a good workaround.
I nearly submitted a bug report insisting this is a kludge, but I backed off. It is all comms local to the host, so I’m not too bothered by it. If you set up a stand-alone render node it will be able to be configured for proper HTTPS.
Hi, is there already a solution for the localhost problem without the workaround to ignore https errors?
Hi
I´m having a similar problem using the JSON plugin for Grafana | Grafana Labs. When I try to connect to my backend API in the localhost, I get the error “Failed to fetch:net::ERR_CERT_AUTHORITY_INVALID.”
I´ve tried to edit the C:\Program Files\GrafanaLabs\grafana\conf\defaults.ini with the following lines and then I restarted the server but it does not work.
[plugin.simpod-json-datasource]
I really appreciate any help you can provide.
The rendering_ignore_https_errors config parameter is specific to the grafana-image-renderer plugin. There would need to be some similar parameter available to call for the simpod-json-datasource plugin to be able to define it in defaults.ini. My cursory glance at the GitHub repo for simpod-json-datasource did not reveal any similar parameter options.
beware of "rendering_ignore_https_errors = " being set several times
Had "rendering_ignore_https_errors = " empty in my .ini template, therefore when I inserted it with true above, it was was unset after being set. Can be considered a stupid error, but for some this might be a useful hint.
Thank you for sharing the solution!
