Iframe - Node -Red - localhost not working
I am using Grafana 10.0.2 OSS deployed on a Raspberry Pi Zero W
In the grafana.ini I have change the following
allow_embedding = true
If I use in the templet node the below it renders the iframe
src=“http://10.0.0.9:3000/d/b30f91e3-65eb-4455-a6f9-ef6978252c56/time?orgId=1&viewPanel=1
th=“1250” height=“1200” frameborder=“0”>
If I use the below it doesn’t.
src="http://grafana.staged-by-discourse.com/d/b30f91e3-65eb-4455-a6f9-ef6978252c56/time?orgId=1&viewPanel=1"
    th="1250" height="1200" frameborder="0"
Are there any other way of rendering a iframe using localhost?
Thank you.
Hi @mwengiineeringbuild
Did you see/try this?
I am not sure where he is enabling it.
I did create a custom.ini but the problem persist.
I had the same issue some time back, this is my solution.
        "id": "b85beb3020cb85e9",
        "type": "inject",
        "z": "b2928c32a81fdfda",
        "name": "",
        "props": [
                "p": "payload"
        "repeat": "30",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 130,
        "y": 40,
        "wires": [
                "572bf84e0c86f5d8"
        "id": "572bf84e0c86f5d8",
        "type": "exec",
        "command": "hostname -I",
        "addpay": "",
        "append": "",
        "useSpawn": "false",
        "timer": "",
        "winHide": false,
        "oldrc": false,
        "name": "",
        "x": 290,
        "y": 40,
        "wires": [
                "05976c142dadc573"
        "id": "f3d991dbcf24a13b",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "hostIP",
                "pt": "flow",
                "to": "payload[0]",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 600,
        "y": 40,
        "wires": [
                "adf363cf5d976d3b"
        "id": "adf363cf5d976d3b",
        "type": "function",
        "name": "iframe",
        "func": "let ip = flow.get(\"hostIP\")\n\n\nmsg.template = \"<iframe src='http://\" + ip + \":3000/d/b30f91e3-65eb-4455-a6f9-ef6978252c56/time?orgId=1&viewPanel=1' th='1250'height='1200' frameborder='0'></iframe>'\"\n\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 770,
        "y": 40,
        "wires": [
                "350283267f5d33d9"
        "id": "350283267f5d33d9",
        "type": "ui_template",
        "group": "402776970d60e884",
        "name": "",
        "order": 2,
        "width": "28",
        "height": "14",
        "format": "",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 940,
        "y": 40,
        "wires": [
        "id": "05976c142dadc573",
        "type": "function",
        "name": "split",
        "func": "let a = msg.payload.split(' ')\n\nmsg.payload = a\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 430,
        "y": 40,
        "wires": [
                "f3d991dbcf24a13b"
        "id": "402776970d60e884",
        "type": "ui_group",
        "name": "Aquponics",
        "tab": "2a017e33ebbf9d66",
        "order": 1,
        "disp": true,
        "width": "28",
        "collapse": false,
        "className": ""
        "id": "2a017e33ebbf9d66",
        "type": "ui_tab",
        "name": "Aquaponics Control",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
