Icon in PLCnext disapear
I’m using a plcnext 2152 from pheonix contact, and using grafana with the app they propose on there store ( i don’t know the grafana version)
I want to use custom icons inside of a canva panel
I put my .png inside the plc with WinSCP, then i move it with : podman cp 60002172000510_grafana_1:/usr/share/grafana/public/img/icons/unicons/
  • What happened?
it work and i can use my icons, the problem come when i restart my plc, the icons disapear from the canva and there are no more selectable.
Not disapear because i think when i copy my png inside the container it would be save in the memory forever
No error
I try to follow this : https://www.youtube.com/watch?v=ZIjUOr_HYFQ
Step 1: Store icons on PLC
Create folder:
mkdir -p /opt/grafana-icons
Upload your .png files there using WinSCP
Step 2: Copy icons into container
After PLC starts, run:
podman cp /opt/grafana-icons/. 60002172000510_grafana_1:/usr/share/grafana/public/img/icons/unicons/
Step 3: Refresh Grafana
you can see your grafana version in grafana ui
here.
my version is : Grafana v11.3.0 (d9455ff7db)
It work but only for a moment
First if i creat the folder with mkdir i don’t have the permission to put my images, so i creat it manually in winscp and it work.
Then i use the cmd you gave me and my icons are usable
Bur when i restart my plc icons disapear
i still have the emplacement but not the visual
And it don’t appear ether in the icons list
So i don’t know how to di for not making them disapear
help please
