Hi Sir,
I wanna change preloader icon. In this folder(/usr/share/grafana/public/img) I changed all grafana icon images but still showing the same icon .
Thanks for answers.
Hi Sir,
Thanks for answers.
It’s inline in the html file
thanks for answers if you are saying about/usr/share/grafana/public/views/index file, nothing has changed despite deleting that file
thank you for answer I solved .problem is just grafana servis restart
Hey Netxx,
I want to achieve the same outcome, can you please tell me what needs to be done. As I can see in index.html, there are two icon images one is under /public/img/ and under is inline/embedded in index.html.
What I need to do
