I am developing a webpage (in a portal) where Graphs from Grafana in embedded. (using
Eg:
Note: The Graphs is not displayed as grafana is running in my private network
it is works very well. But when the graph loads, it shows bouncing Grafana Icon. Is there a way to remove this. I search this community and I received few suggestions and none of the suggestions work.
What I did was I went into the folder
/usr/share/grafana/public/views
opened the index.html
edited the following line
href=“[[.ContentDeliveryURL]]public/img/grafana_mask_icon.svg”
In this line, I replaced the grafana_mask_icon.svg with my own svg file which stored in /usr/share/grafana/public/img
But that did not make any impact. I restarted grafana still it did not make any change.
I modified every html file in this folder and replaced grafana_mask_icon.svg with my own svg file which is stored in /usr/share/grafana/public/img and that did not make any 1
impact.
Restarted grafana again. Still no change.
Can any help me give me a hint on where I an going wrong with this ?
