i just started using grafana canva recently and i seemed to notice that i can not create an individual element threshold, what appears to be a group threshold is all i can work with. will you please look into creating an individual element threshold that would not affect other elements.
it’s showing the same color as if it is a group threshold.
I am looking for a solution on how I can go about creating an individual threshold any idea on the path or route i can take to get it done thanks.
