Threshold from variable
Hi folks,
Can someone help me to create thresholds?
I have static variable for example int = 10
Also, I have dynamic var, that can be changed from 10 to any lower number, so I would like to create a threshold for the dynamic var that will be based on static var1
So when dynamic var will != 10, panel color should be changed
Is it possible ?)
I’m quite interested for this feature too, and I didn’t find how to do it.
I’m eager to ear for a solution :wink:
