For solving colour threshold problem for each element follow these Steps
Introduction: If you are encountering a problem setting colour thresholds individually, you can follow these steps to solve this issue with the easiest solution provided below.
Step 1: Click on add field override and add field with name
Step 2: Now add override property and select thresholds>thresholds
Step 3: Now add your desired threshold properties
Final result
Conclusion
The migration from the Flowcharting plugin to the Canvas plugin in Grafana 10.4 involved a series of systematic steps: importing the old dashboard, exporting and converting the visual elements, and reconfiguring the dashboard with dynamic data updates. This process ensures that the client’s dashboard remains functional and supported, with improved performance and adaptability in the newer Grafana environment.
Shanker Agarwal
(Grafana Architect)
shanker.agarwal@dataabsolute.com
