Canvas Visualization thresholds by Element
It’s just a suggestion, but I think it would be very useful if for each element that is added using the canvas plugin, a specific threshold could be set. In this way, for example if there are several network links, each of the elements can have a specific threshold.
Currently with the global threshold, it applies to all metrics and although it can be corrected by calculating the % of bandwidth usage, it would be easier if it were a property of each element.
Thank you so much!!
